dean_wheatley
Aug 15, 2013Aspirant
Disk quota issues
hi, I have a ReadyNAS 4200 device and after looking into setting up disk quotas on Home/user folders I added a 30gb limit to an AD user group, however some of our developers were part of that grou...
dean_wheatley
Thanks for the reply..
I did the reboot with the quota check option checked under 4.2.22, but that changed nothing
Is there a significant difference to update from 4.2.22 to 4.2.24?, ie Is this quota issue a know problem and 4.2.24 will fix it? as I am reluctant to run the update in case there are other adverse effects
I have also noticed there are 2 files in the root of c when viewing the shares from a domain admin account. aquota and aquota.user, seems likely that these could be a cause?, If I deleted them is it likely to cause other problems?
Dean
Dean
