dean_wheatley
Aug 15, 2013Aspirant
Disk quota issues
hi, I have a ReadyNAS 4200 device and after looking into setting up disk quotas on Home/user folders I added a 30gb limit to an AD user group, however some of our developers were part of that grou...
mdgm-ntgr
Aug 15, 2013NETGEAR Employee Retired
Have you confirmed that there is neither a quota for the user nor the group?
When you rebooted to do the quota check did you select to do a volume scan as well? if so, try it again but this time only select to do a quota check.
What web browser and version did you use to set the quotas? Note that 4.2.23 added compatibility with IE10. I'm not sure if there was a compatibility issue with setting quotas though.
If you like you could contact tech support and if all else fails they could remotely login to the unit to fix the quotas.
