torbuk
Dec 30, 2011Aspirant
Disk Scrubbing causes ReadyNAS Pro to lock up
The company I do technical support for has a ReadyNAS Pioneer Pro. I have been experiencing an issue where when I enable the "Disk Scrubbing with Auto Parity Fix" Volume Maintenance (set for every tw...
mdgm-ntgr
Dec 30, 2011NETGEAR Employee Retired
Some of your drives are not on the Hard Disk HCL. The disks in Ch 5 & 6 are most likely to be the problem in my view, but it could be one or more of the other disks.
You might wish to run the "Disk Test" boot option (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
