Newvettedc
Jul 29, 2016Aspirant
Display shows Retry Startup #27234130
I have a Netgear 314 drive that has a flashing blue light on the Power button. The display shows Retry Startop and I have tried booting up from the boot menu as Normal and I have now tried to reb...
- Aug 09, 2016
I understand that the problem has now been fixed by support.
Yes, you should update the firmware. On the latest firmware (6.5.1), the NAS will automatically try to repair the problem if it runs into the issue your system ran into.
Note that the issue you ran into is one problem that has the symptom of failing to complete booting and giving the "Retry Startup" error.
There are some general tips on updating the firmware: http://kb.netgear.com/app/answers/detail/a_id/30033/~/readynas-os-6%3A-firmware-upgrade-guide-and-tips
Newvettedc
Aug 01, 2016Aspirant
Is there a way you can confirm RN31400 drive is registered properly? I receive confirmation so it should be ok. The email domain is the same. So more I have not had much luck connecting directly but I may not be doing everything correctly.
Newvettedc
The display still is showing Retry Startup. When I connect directly to the drive from the PC I do get a connection but it shows (still shows) off line busy. So even though I have a direct connection I can not get passed the busy indication from ReadyNAS. I have about exhausted the things I know to do open to suggestion but I need some help. Once again I did reload the OS from the firmware and logon and password are at the default settings.
The drive shows Retry Startup. ReadyNAS shows drive is busy.
RAIDar connect now with IP 169.254.202.73
Is there any other opations or do I need to call Support?
