Newvettedc's avatar
Newvettedc
Display shows Retry Startup #27234130
  I have a Netgear 314 drive that has a flashing blue light on the Power button. The display shows Retry Startop and I have tried booting up from the boot menu as Normal and I have now tried to reb...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 09, 2016
    I understand that the problem has now been fixed by support.
    Yes, you should update the firmware. On the latest firmware (6.5.1), the NAS will automatically try to repair the problem if it runs into the issue your system ran into.
    Note that the issue you ran into is one problem that has the symptom of failing to complete booting and giving the "Retry Startup" error.
    There are some general tips on updating the firmware: http://kb.netgear.com/app/answers/detail/a_id/30033/~/readynas-os-6%3A-firmware-upgrade-guide-and-tips
ProSupport for Business
