ScottyPottie
Apr 25, 2009Aspirant
DLNA Playlist
Hello,
Are playlists supported? If so what format do they need to be in? I can't get them to show up on my devices. Photos and MP3s are working fine.
Update:
Just in case support is going to be added, here is what I found:
When testing, I am able to get WMP11 to share playlists and my devices can play them via UPnP share.
You cannot find them by browsing through the folders through. You have to use a Playlist menu item.
At the top level, the WMP share has:
MUSIC
VIDEO
PICTURES
PLAYLISTS
Under MUSIC there is also a "Music Playlists" Menu item.
The ReadyNas Share has:
MUSIC
PICTURES
VIDEO
==> No option to get to playlists.
Devices: Archos 5, Phillips NP2900
Update:
MUSIC
VIDEO
PICTURES
PLAYLISTS
MUSIC
PICTURES
VIDEO
- alokeprasadMentorWhere do you keep the m3u files? In each individual directories? In the root directory that ReadyDLNA is scanning/monitoring?
What directory names do you use in the m3u files to refer to the target mp3 files? relative addressing? - akamanAspirantGreat question, alokeprasad. Anyone able to help? that will speed my tests along quite a bit. TIA.
