ipb_uk
Jul 19, 2023Aspirant
DLNA rebuild - rescan
RNDP6000-v2 V6.10.8 Something is wrong with the dlna part on this nas. When the nas is rebooted it deletes the files.db and starts to rescan. What needs to be done to stop it deleting the file and r...
schumaku
Jul 19, 2023Guru - Experienced User
Mid term, an update to v6.10.9 would be smarter (due to the fixes applied in the package handling) than re-update for hope-and-pray.
If minidlnad does find errors from the previous run, it will re-do the re-scan from scratch. Have an eye in the related log if available FMI.
Just wonderiing - does the scan complete w/o error before the next reboot?
