davidr1
Jun 15, 2011Luminary
Doing one's own rsync and cron scripts
Hi, As, IMHO, the Ultra's GUI interface is appalling, it does not give me the backup versatility I want wth rsync and cron jobs. (Ducking the flames) Is there anything that would cause Frontview...
davidr1
Jun 17, 2011Luminary
Thanks mdgm,
It doesn't seem there are inherent problems in Frontview to do this I don't know about then - thanks.
Though I don't know how to instruct ~ReadyNAS to terminate power to the USB ports - if it is even possible. My USB drives gives me no indication they have been unmounted.
Thanks for your help.
David
Agreed - but I'm used to 'once set - forget'.
won't obviously get the benefits of viewing and configuring jobs in Frontview
true though I should be able to set the text file output to a location on a share (or on my computer). In either case, in linux I should be able to pick these up and have them forwarded to me by email.
or Frontview's email alerts about backup jobs
True - I was hoping to be able to set it up so it doesn't interfere with Frontview - maybe even allowing Frontview scheduling still to work if desired.
you won't get help with this from tech support.
David
