glashoppah
Jan 03, 2012Aspirant
Drive replacement issue in Pro Business
Dear Forum Members, I have a Pro Business with 6x Seagate Constellation ES 2TB drives. I had noticed over the past two months a climbing error count on Disk 3, with the drive finally failing the S...
glashoppah
I cleared the cache, same displays. What I'm trying to figure out is, if the drive is "Dead", why does it display as OK on the front panel and in RAIDar, and why does the log say it's being used in a rebuild?
H.
P.S. The Seagates I bought (and that are failing) are the Constellation ST32000644NS, right off the HCL... :(
H.
