glashoppah
Jan 03, 2012Aspirant
Drive replacement issue in Pro Business
Dear Forum Members, I have a Pro Business with 6x Seagate Constellation ES 2TB drives. I had noticed over the past two months a climbing error count on Disk 3, with the drive finally failing the S...
glashoppah
Here is the total contents of diagnostics.log (S/Ns redacted):
I also tried removing and re-inserting the drive, and the displays got weirder - the health indicator showed the drive still in and "Dead", RAIDar showed "yellow", and the log reflected the removal. When I replaced it, RAIDar showed "Green", the health indicator still said "Dead", and the logs did not reflect the re-insertion. My main issue here is the discrepancies between the different indicators.
H.
Disks
* Disk 0 (model Seagate ST32000644NS, serial number ********) has 1 reallocated sectors. Reallocated sectors might be acceptable, but they are often the first warning sign that a disk is starting to fail.
* Disk 1 (model Seagate ST32000644NS, serial number ********) has 2 reallocated sectors. Reallocated sectors might be acceptable, but they are often the first warning sign that a disk is starting to fail.
* Disk 5 (model Seagate ST32000644NS, serial number ********) has 1 reallocated sectors. Reallocated sectors might be acceptable, but they are often the first warning sign that a disk is starting to fail.
Memory
Passed diagnostics.
Network
Passed diagnostics.
Performance
* Jumbo frames are disabled on Ethernet<1+2>. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
* Jumbo frames are disabled on interface 1. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
* Jumbo frames are disabled on interface 2. If both your switch and clients support jumbo frames, you can enhance your write performance by enabling jumbo frames on this interface.
Volume
Passed diagnostics.
H.
