spinaltap1
Jun 01, 2013Aspirant
Drive Size Order?
I have a NV+v2, with a 500Gb drive in bay 1 and a 2Tb drive in bay 2 (both Seagate), and I am thinking about buying another drive. Option A would be to buy another 2Tb drive to replace the 500Gb dr...
Jun 01, 2013Guru - Experienced User
You are using jbod I think? If so, you'd back up the 500 GB volume, then delete it and remove the drive. Then put in the new drive in the same slot and create a new volume / restore the data.
I suggest searching the forum for your drive model before purchase - there are some drives on the HCL that don't seem to have worked out so well.
