spinaltap1
Jun 01, 2013Aspirant
Drive Size Order?
I have a NV+v2, with a 500Gb drive in bay 1 and a 2Tb drive in bay 2 (both Seagate), and I am thinking about buying another drive. Option A would be to buy another 2Tb drive to replace the 500Gb dr...
spinaltap1
Jun 02, 2013Aspirant
StephenB wrote: You are using jbod I think?
What is 'jbod'?
I have checked the HCL; and my choice is between WD Red WD30EFRX or Seagate Barracuda ST3000DM001.
Is it possible to replace the 500Gb drive with my existing 2Tb drive in bay 1...
...and then insert the new 3Tb drive in bay 2, so that the data in drive 1 automatically mirrors to the new 3Tb drive in bay 2?
