spinaltap1
Jun 01, 2013Aspirant
Drive Size Order?
I have a NV+v2, with a 500Gb drive in bay 1 and a 2Tb drive in bay 2 (both Seagate), and I am thinking about buying another drive. Option A would be to buy another 2Tb drive to replace the 500Gb dr...
Jun 02, 2013Guru - Experienced User
JBOD: "Just a Bunch Of Disks"; an array of drives, each of which is accessed directly as an independent drive
You have two mismatched drives now (500 GB and 2 TB). Are you using XRAID-2 (giving you a single 500 GB volume), or do you have two volumes (one 500 GB and one that is either 1.5 TB or 2 TB)???
Basically you can
(a) forget about RAID and create 5 TB total storage space (not redundant at all)
(b) Use XRAID2 and get 2 TB total storage space (wasting 1 TB, but fully redundant)
(c) Use FlexRAID and get 2 TB of redundant RAID-1 storage, and 1 TB of additional non-redundant space
Picking (a), (b) or (c) is the first choice. How you migrate your data will depend on what you chose, and what you have now.
BTW, personally, I recommend the WD30EFRX over the ST3000DM001. Either way, search the forum for other user experiences, don't just pick something off the HCL.
Basically you can
