spinaltap1
Jun 01, 2013Aspirant
Drive Size Order?
I have a NV+v2, with a 500Gb drive in bay 1 and a 2Tb drive in bay 2 (both Seagate), and I am thinking about buying another drive. Option A would be to buy another 2Tb drive to replace the 500Gb dr...
mdgm-ntgr
Jun 03, 2013NETGEAR Employee Retired
What is important is that smallest drives are installed first. The NAS is smart enough to handle higher capacity disks being in different bays. If the drive in bay 1 is the drive you are replacing then you should put the replacement drive in bay 1
