spinaltap1's avatar
spinaltap1
Drive Size Order?
I have a NV+v2, with a 500Gb drive in bay 1 and a 2Tb drive in bay 2 (both Seagate), and I am thinking about buying another drive.
Option A would be to buy another 2Tb drive to replace the 500Gb drive in bay 1.
However, if I purchased 3Tb drive (haven't decided between WD Red or Seagate Barracuda), what is the best way of installing it?
That is, I want to end up have the existing 2Tb drive in bay 1 and the 3Tb drive in bay 2.
  • StephenB's avatar
    spinaltap wrote:
    So I should end up with mirrored 2 x 2Tb capacity (with 1Tb being redundant on the 3Tb drive).
    Mirrored 2 TB volume with 1 TB of the 3 TB drive unused [I suspect that is what you meant to type].
ProSupport for Business
