Doc_Holliday's avatar
Doc_Holliday
Drive spindown does not work correctly with firmware newer then 6.2.2 (RN-102)
Hi all,
with firmware 6.2.2 drive spindown works as expected. Drives are stopping after 20 minutes and remain stopped until NAS is accessed from any computer. With newer firmware (6.2.3, 6.2.4, not tested 6.4.0) they spin down too but start again after some seconds. After some hours without any changes I went back to 6.2.2 and everything was ok.
Is there a solution to this problem? Is it solved with 6.4.0 (because downgrade is not possible)?
My NAS is the RN-102 and the hard drives are two Toshiba DT01ABA300.
  • I found an old log from april when I tested 6.2.3 for the first time. Here are some excerpts. I found nothing other related to the timestamps when disks spinned up.
    systemd-journal.log
    Apr 26 16:52:49 readynas noflushd[1040]: Spinning down disk 1 (/dev/sda).
    Apr 26 16:52:51 readynas kernel: Disk [0] going to standby...
    Apr 26 16:52:52 readynas noflushd[1040]: Spinning down disk 2 (/dev/sdb).
    Apr 26 16:52:54 readynas kernel: Disk [0] going to standby...
    Apr 26 17:01:35 readynas kernel: Disk [0] spinning up...
    Apr 26 17:01:44 readynas noflushd[1040]: Spinning up disk 1 (/dev/sda) after 0:08:52.
    Apr 26 17:01:44 readynas noflushd[1040]: Spinning up disk 2 (/dev/sdb) after 0:08:50.
    Apr 26 17:16:55 readynas connmand[1036]: ntp: time slew +1.394640 s
    Apr 26 17:17:03 readynas CRON[3406]: pam_unix(cron:session): session opened for user root by (uid=0)
    Apr 26 17:17:03 readynas CRON[3407]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    Apr 26 17:17:03 readynas CRON[3406]: pam_unix(cron:session): session closed for user root
    Apr 26 17:17:13 readynas connmand[1036]: ntp: time slew +0.000720 s
    Apr 26 17:17:29 readynas connmand[1036]: ntp: time slew +0.000730 s
    Apr 26 17:17:43 readynas dbus[1048]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
    Apr 26 17:17:43 readynas snapperd[3417]: Requesting DBus name
    Apr 26 17:17:43 readynas dbus[1048]: [system] Successfully activated service 'org.opensuse.Snapper'
    Apr 26 17:17:43 readynas snapperd[3417]: Loading snapper configs
    Apr 26 17:17:43 readynas snapperd[3417]: Listening for method calls and signals
    Apr 26 17:18:01 readynas connmand[1036]: ntp: time slew +0.000782 s
    Apr 26 17:18:49 readynas smbd[4012]: pam_unix(samba:session): session closed for user guest
    Apr 26 17:18:49 readynas smbd[4013]: pam_unix(samba:session): session closed for user guest
    Apr 26 17:19:05 readynas connmand[1036]: ntp: time slew +0.001148 s
    Apr 26 17:19:54 readynas snapperd[3417]: Exiting
    Apr 26 17:21:14 readynas connmand[1036]: ntp: time slew +0.002330 s
    Apr 26 17:21:47 readynas noflushd[1040]: Spinning down disk 1 (/dev/sda).
    Apr 26 17:21:49 readynas kernel: Disk [0] going to standby...
    Apr 26 17:21:50 readynas noflushd[1040]: Spinning down disk 2 (/dev/sdb).
    Apr 26 17:21:50 readynas kernel: Disk [0] spinning up...
    Apr 26 17:21:52 readynas kernel: Disk [0] going to standby...
    Apr 26 17:21:52 readynas kernel: Disk [0] spinning up...
    Apr 26 17:21:57 readynas noflushd[1040]: Spinning up disk 1 (/dev/sda) after 0:00:07.
    Apr 26 17:21:57 readynas noflushd[1040]: Spinning up disk 2 (/dev/sdb) after 0:00:05.
    Apr 26 17:25:31 readynas connmand[1036]: ntp: time slew +0.005496 s
    Apr 26 17:34:04 readynas connmand[1036]: ntp: time slew +0.008410 s
    Apr 26 17:41:58 readynas noflushd[1040]: Spinning down disk 1 (/dev/sda).
    Apr 26 17:42:00 readynas kernel: Disk [0] going to standby...
    Apr 26 17:42:01 readynas noflushd[1040]: Spinning down disk 2 (/dev/sdb).
    Apr 26 17:42:03 readynas kernel: Disk [0] going to standby...
    Apr 26 17:44:51 readynas kernel: Disk [0] spinning up...
    Apr 26 17:45:00 readynas noflushd[1040]: Spinning up disk 1 (/dev/sda) after 0:02:59.
    Apr 26 17:45:00 readynas noflushd[1040]: Spinning up disk 2 (/dev/sdb) after 0:02:56.
    Apr 26 17:51:09 readynas connmand[1036]: ntp: time slew +0.022796 s
    system.log
    Apr 26 15:16:58 readynas nmbd[1134]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections
    Apr 26 15:17:01 readynas CRON[1209]: pam_unix(cron:session): session opened for user root by (uid=0)
    Apr 26 15:17:01 readynas CRON[1210]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    Apr 26 15:17:01 readynas CRON[1209]: pam_unix(cron:session): session closed for user root
    Apr 26 15:17:15 readynas dbus[1048]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
    Apr 26 15:17:15 readynas snapperd[1243]: Requesting DBus name
    Apr 26 15:17:15 readynas dbus[1048]: [system] Successfully activated service 'org.opensuse.Snapper'
    Apr 26 15:17:15 readynas snapperd[1243]: Loading snapper configs
    Apr 26 15:17:15 readynas snapperd[1243]: Listening for method calls and signals
    Apr 26 15:17:20 readynas apache2[1142]: [error] (9)Bad file descriptor: apr_socket_accept: (client socket)
    Apr 26 15:17:21 readynas nmbd[1134]: [2015/04/26 15:17:21.932808,  0] ../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
    Apr 26 15:17:21 readynas nmbd[1134]: ***** Samba name server READYNAS is now a local master browser for workgroup WORKGROUP on subnet 192.168.178.25 *****
    Apr 26 15:17:23 readynas apache2[1136]: [warn] RSA server certificate CommonName (CN) `readynas.local' does NOT match server name!?
    Apr 26 15:17:23 readynas apache2[1136]: [warn] long lost child came home! (pid 1137)
    Apr 26 15:17:23 readynas apache2[1136]: [warn] long lost child came home! (pid 1141)
    Apr 26 15:18:18 readynas smbd[1906]: pam_unix(samba:session): session closed for user guest
    Apr 26 15:18:18 readynas smbd[1907]: pam_unix(samba:session): session closed for user guest
    Apr 26 15:19:31 readynas snapperd[1243]: Exiting
    Apr 26 16:17:01 readynas CRON[2225]: pam_unix(cron:session): session opened for user root by (uid=0)
    Apr 26 16:17:01 readynas CRON[2226]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    Apr 26 16:17:01 readynas CRON[2225]: pam_unix(cron:session): session closed for user root
    Apr 26 16:17:31 readynas dbus[1048]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
    Apr 26 16:17:31 readynas snapperd[2236]: Requesting DBus name
    Apr 26 16:17:31 readynas dbus[1048]: [system] Successfully activated service 'org.opensuse.Snapper'
    Apr 26 16:17:31 readynas snapperd[2236]: Loading snapper configs
    Apr 26 16:17:31 readynas snapperd[2236]: Listening for method calls and signals
    Apr 26 16:19:41 readynas snapperd[2236]: Exiting
    Apr 26 16:30:28 readynas apache_access[1465]: 2003:4a:ce3c:5800:f10c:7d33:444b:5d62 "GET / HTTP/1.1" 302
    Apr 26 16:30:40 readynas apache_access[1465]: 2003:4a:ce3c:5800:f10c:7d33:444b:5d62 "GET / HTTP/1.1" 302
    Apr 26 16:31:19 readynas apache_access[1465]: Suppressed 1 duplicate messages
    Apr 26 16:32:16 readynas apache_access[1465]: 2003:4a:ce3c:5800:f10c:7d33:444b:5d62 "POST /dbbroker HTTP/1.1" 200
    Apr 26 16:32:29 readynas dbus[1048]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
    Apr 26 16:32:29 readynas snapperd[2984]: Requesting DBus name
    Apr 26 16:32:29 readynas dbus[1048]: [system] Successfully activated service 'org.opensuse.Snapper'
    Apr 26 16:32:29 readynas snapperd[2984]: Loading snapper configs
    Apr 26 16:32:29 readynas snapperd[2984]: Listening for method calls and signals
    Apr 26 16:33:00 readynas smbd[3122]: pam_unix(samba:session): session closed for user guest
    Apr 26 16:33:00 readynas smbd[3123]: pam_unix(samba:session): session closed for user guest
    Apr 26 16:34:29 readynas snapperd[2984]: Exiting
    Apr 26 17:59:07 readynas smbd[4165]: pam_unix(samba:session): session closed for user guest
    spindown.log
    Apr 26 15:16:50 readynas noflushd[1040]: Enabling spindown for disk 1 [sda,0:0:TOSHIBA_DT01ABA300:231AZ03GS:MZ6OAB0B:5940]
    Apr 26 15:16:50 readynas noflushd[1040]: Enabling spindown for disk 2 [sdb,0:1:TOSHIBA_DT01ABA300:2317UDDGS:MZ6OAB0B:5940]
    Apr 26 15:57:47 readynas noflushd[1040]: Spinning down disk 1 (/dev/sda).
    Apr 26 15:57:50 readynas noflushd[1040]: Spinning down disk 2 (/dev/sdb).
    Apr 26 16:00:35 readynas noflushd[1040]: Spinning up disk 1 (/dev/sda) after 0:02:45.
    Apr 26 16:00:35 readynas noflushd[1040]: Spinning up disk 2 (/dev/sdb) after 0:02:43.
    Apr 26 16:20:36 readynas noflushd[1040]: Spinning down disk 1 (/dev/sda).
    Apr 26 16:20:38 readynas noflushd[1040]: Spinning down disk 2 (/dev/sdb).
    Apr 26 16:21:57 readynas noflushd[1040]: Spinning up disk 1 (/dev/sda) after 0:01:19.
    Apr 26 16:21:58 readynas noflushd[1040]: Spinning up disk 2 (/dev/sdb) after 0:01:17.
    kernel.log
    Apr 26 15:16:51 readynas kernel: eth0: started
    Apr 26 15:57:49 readynas kernel: Disk [0] going to standby...
    Apr 26 15:57:52 readynas kernel: Disk [0] going to standby...
    Apr 26 16:00:26 readynas kernel: Disk [0] spinning up...
    Apr 26 16:20:38 readynas kernel: Disk [0] going to standby...
    Apr 26 16:20:40 readynas kernel: Disk [0] going to standby...
    Apr 26 16:21:49 readynas kernel: Disk [0] spinning up...
    event_push.log
    [15/04/26 15:57:47] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430056727" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 15:57:50] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430056730" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 16:00:35] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430056845" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
     0 0 ==> ec=0
    [15/04/26 16:20:36] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430058096" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 16:20:38] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430058098" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 16:21:58] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430058128" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
     0 0 ==> ec=0
    [15/04/26 16:52:49] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430060029" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 16:52:52] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430060032" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:01:44] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430060514" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:01:45] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430060515" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:21:47] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430061767" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:21:50] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430061770" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:21:57] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430061727" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
     0 0 ==> ec=0
    [15/04/26 17:41:58] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430062978" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:42:01] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430062981" priority="1" key="478" string="Disks sleeping.."/></xs:add-s>
     0 0 ==> ec=0
    [15/04/26 17:45:00] event_push.c:186 rnutil readynasd <xs:add-s resource-type="Lcd">
      <lcd expiration="1430063110" priority="1" key="478" string="Disks waking..."/></xs:add-s>
     0 0 ==> ec=0
     0 0 ==> ec=0
    cron.log
    Apr 26 15:16:50 readynas cron[1035]: (CRON) INFO (pidfile fd = 3)
    Apr 26 15:16:50 readynas cron[1035]: (CRON) INFO (Running @reboot jobs)
    • Doc_Holliday's avatar
      Doc_Holliday
      No ideas? Anybody with the same NAS, disks and settings who can tell their experiences?
      Thx in advance
  • kohdee's avatar
    kohdee
    Administrator
    Did you install something new after upgrade to 6.2.3?  believe I saw that someone tested 6.4.0 and saw disk-spindown working fine. Do you have volume maintenance enabled?
      Doc_Holliday
      No, I did not install anything. I have no add-ons installed at all. There are no maintenance schedules defined.
      I will try to get a log with 6.2.3 or 6.2.4.
        Doc_Holliday
        I found a complete log from end of april 2015 when I tested 6.2.3 for the first time. Here are some extracts from the logs. In the other files I do not find anything related to the timestamps when disks spinned up. Where can I have an additional look to?
        event_push.log
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
         0 0 ==> ec=0
        cron.log
        kernel.log
         spindown.log
        systemd-journal.log
ProSupport for Business
