SimonClark100
Apr 17, 2023Aspirant
Drives moved to NAS 104 from another NAS 104 say volume is redundant why?
I have 2 NAS 104's and I purchased the second one just to keep as a hardware backup. The chassis seems to have died and will no longer finish booting. I've tried OS recovery but it never seems to com...
Apr 17, 2023Guru - Experienced User
SimonClark100 wrote:
So, I put plan B into action and moved the drives to my spare 104 but even though it recognises them it says they contain redundant volumes
Do you mean an inactive volume?
Are you using FlexRAID or X-RAID.
- SimonClark100Apr 17, 2023Aspirant
Stephen, thank you for your reply.
Yes, the exact wording is 'Remove inactive volumes to use the disk. Disk #3,4.
The unit looks configured for X-RAID on both volume sets (green bar under words).
- StephenBApr 18, 2023Guru - Experienced User
Most likely the problem is that volume is simply out of sync. That can happen if there were cached writes that were never written to the disks when the old NAS failed.
I suggest getting the full log zip (download it from the logs page). If you like, you can send me a private message (PM) with a download link to the zip file (dropbox, google drive, etc) and take a look. Best not to post the download link publicly, as there is some privacy leakage (for instance, your email address would be in the log file).
There is a way to forcibly mount the volume from the linux command line. There would be some loss of data (since some writes were lost) - it's hard to say how much. Another option is to connect all four disks to a Windows PC, and use RAID recovery software that supports BTRFS. ReclaiMe is one package that folks have used here with success.
- SimonClark100Apr 18, 2023Aspirant
Stephen,
Thanks for your time and effort.
I don't think I can get a log out of the ill 104 but I can try. I can ping it during boot so maybe I can ssh onto it too. It seems to get stuck preparing the web interface. No files are accessible even though it does show the shares. They just take ages to mount and timeout. I guess I can get a log from the working one and see what if anything it thinks is a reason why it can't mount the drives. I had the system arranged as 2 volumes of mirrors so I'm hoping to recover the data as I don't believe any one of the disks has failed.
I'm just pretty nervous about any settings that could suddently come up and say 'all is fixed, here's your drives nice and empty'. I think I had that once before many years ago by just changing a setting so I'm treading very lightly.
In the mean time I have ordered a 3.5in USB caddy that I can as you say plug the drives into a Windows machine and use some recorvery tools. I think this is will be the safest option and knowing that I have 2 copies of each volume gives me a little reassurance that I'll get this resolved. I do have other back ups but your most recent data is only ever as safe as the last time it was backed up.
At the end of the day the 104 has been an incredibly reliable product and the drives have survived really well (2014 and 2016 WD RED 4TB each). I was in the process of copying all of the data over to new 14TB drives when it failed. Statistically that is very improbable but here I am.
Thanks,
Simon
