chasdrury's avatar
chasdrury
Dropbox integration
Hi
So I want to use DropBox sync - the intial sync has worked for one folder - should i be able to choose multiple shares to sync to dropbox or is it only one at once?
Once the sync is set up are any changes then automatically synced or do i have to do a manual sync everytime?
Cheers!
  • Hello chasdrury,
    Welcome to the community!
    Unfortunately, it is by design that Dropbox of ReadyNAS allows you to sync only one share at a time.
    This has been raised before and we have already requested for for it as an added functionality.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello chasdrury,
    • chasdrury's avatar
      chasdrury
      Thanks
      That's a real shame but good the feature has been requested. It works really nicely for one folder!
ProSupport for Business
