Widget82
Nov 07, 2019Aspirant
Dropbox partially syncing
Hi, I have a readyNAS Pro 6 with 5 2TB WD Red drives running firmware 6.10.2 I am trying to setup a sync with my dropbox business account - specifically the multimedia folder which is too large to ...
- Nov 16, 2019
Hi Widget82,
As discussed via PM, please check if the issue is fixed or not after assigning static DNS addresses to the NAS active interface.
If I remember correctly, the blue dot next to the Dropbox icon means that it is syncing.
JohnCM_S
Nov 08, 2019NETGEAR Employee Retired
Hi Widget82,
Welcome to the Community!
You can try first downloading the NAS system logs and check the dropbox.log. You might find some clues there on what is causing the issue.
