Widget82
Nov 07, 2019Aspirant
Dropbox partially syncing
Hi, I have a readyNAS Pro 6 with 5 2TB WD Red drives running firmware 6.10.2 I am trying to setup a sync with my dropbox business account - specifically the multimedia folder which is too large to ...
- Nov 16, 2019
Hi Widget82,
As discussed via PM, please check if the issue is fixed or not after assigning static DNS addresses to the NAS active interface.
If I remember correctly, the blue dot next to the Dropbox icon means that it is syncing.
JohnCM_S
Nov 13, 2019NETGEAR Employee Retired
Hi Widget82,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
- Widget82Nov 14, 2019Aspirant
Hi JohnCM_S
I typed quite along reply and then lost it as the page wouldn't let me attach the log as a txt file....
The problem has not been resolved. It took me a while to work out that I needed to download the logs to see more detail rather than looking at the summary log in the web interface.
Basically it has been presenting a load of errors over the time I have been trying to get dropbox to sync on the NAS.
These include error codes:
56
6
18
7
28
In my most recent attempt to get it to sync it repeatedly returned this error:
Nov 07 06:09:03 PottingShedNAS ng-csd[3649]: E1107 06:09:03.048760 3683 CurlHttpClient.cpp:427] Curl returned error code 18. Transferred a partial file
Nov 07 06:34:39 PottingShedNAS ng-csd[3649]: Curl returned error code 18. Transferred a partial file
Nov 07 06:34:39 PottingShedNAS ng-csd[3649]: E1107 06:34:39.031913 3906 CurlHttpClient.cpp:427] Curl returned error code 18. Transferred a partial fileI have turned dropbox back on in the cloud services section and will report what errors it comes up with during the day today.
Is there a way that I can attach the error log?
Thanks for any help.
So I have had dropbox activated on the ReadyNAS this afternoon for a few hours.
This is the log that I get from it:
Nov 14 11:45:51 PottingShedNAS systemd[1]: Started Dropbox 2 client for ReadyNAS.
Nov 14 13:42:39 PottingShedNAS ng-csd[20815]: Curl returned error code 18. Transferred a partial file
Nov 14 13:42:41 PottingShedNAS ng-csd[20815]: E1114 13:42:38.655153 20817 CurlHttpClient.cpp:427] Curl returned error code 18. Transferred a partial file
Nov 14 13:46:09 PottingShedNAS ng-csd[20815]: Curl returned error code 18. Transferred a partial file
Nov 14 13:46:10 PottingShedNAS ng-csd[20815]: E1114 13:46:09.243520 20843 CurlHttpClient.cpp:427] Curl returned error code 18. Transferred a partial file
Nov 14 13:46:11 PottingShedNAS ng-csd[20815]: Curl returned error code 18. Transferred a partial file
Nov 14 13:46:11 PottingShedNAS ng-csd[20815]: E1114 13:46:11.150558 20818 CurlHttpClient.cpp:427] Curl returned error code 18. Transferred a partial file- JohnCM_SNov 14, 2019NETGEAR Employee Retired
Hi Widget82,
You can upload the complete system logs to file-sharing site then send me the download link via PM (private message) so we can check the complete logs.
