Widget82
Nov 07, 2019Aspirant
Dropbox partially syncing
Hi, I have a readyNAS Pro 6 with 5 2TB WD Red drives running firmware 6.10.2 I am trying to setup a sync with my dropbox business account - specifically the multimedia folder which is too large to ...
- Nov 16, 2019
Hi Widget82,
As discussed via PM, please check if the issue is fixed or not after assigning static DNS addresses to the NAS active interface.
If I remember correctly, the blue dot next to the Dropbox icon means that it is syncing.
JohnCM_S
Nov 14, 2019NETGEAR Employee Retired
Hi Widget82,
You can upload the complete system logs to file-sharing site then send me the download link via PM (private message) so we can check the complete logs.
JohnCM_S
Nov 16, 2019NETGEAR Employee Retired
Hi Widget82,
