danielw
Apr 30, 2013Aspirant
Dropbox Syncing Problems
Hi Guys, I am currently using the new Netgear NAS 102 with the OS 6.0.4 firmware on it and am having issues with Dropbox sync I hope you can help with. I have set the DropBox to syncronise my ...
chirpa
May 02, 2013Luminary
Looking at the /frontview/bin/fvdropbox binary, it uses the curl library to call dropbox.com APIs directly. Maybe there is an atomic timestamp issue, that it thinks the remote files are newer, so it downloads them again each time the service starts. It then uses inotify to find changed files, and upload them.
(r2d2, nothing confidential here. I used the 'strings' command (binutils package), which shows ascii text in binaries.)
Maybe this 'mode' could be changed to become a one-way push to dropbox, not bi-directional.
# strings /frontview/bin/fvdropbox
DropBox utitlity and sync server
This probram use 'parson' (a light json parser and reader) by Krzysztof Gabls, under MIT license.
See http://kgabis.github.com/parson/ for 'parson'.
# %s -h ... show this help
# %s [-v 0..3] ... start service
# %s [-v n] [-V] [-d] ... start service
# %s [-v n] [-V] -- cmd args... ... run utility command
-v n ... verbose. n=0..3.
-d ... debug service without started by systemd
info ... Get user info. (call /account/info API.)
... File listing. (call /metadata API.)
put [-f] local_path remote_path
... Upload file. (call /file_put API.) (Up to 150MB)
-f : forces update. otherwise update if newer.
get [-f] remote_path local_path
... Download file. (call /files (GET) API.)
-f : force download. otherwise download if newer.
sync [-c cursor] remote_folder local_folder
... Download all if newer. Then upload all if newer.
... Get file/directory info. (call /metadata API.)
-l : with list=true (default: list=false)
upload [-f] local_path remote_path
... Upload file. (call /chunked_upload API.)
... Create a folder (call /create_folder API.)
... Delte folder or file (call /delete API.)
This program should be started by systemd.
# /frontview/bin/fvdropbox -v 2 -V -d -- infoIf you change the "-v 2" to "-v 3", you can see all the debug values. Scary that they don't verify the SSL certificate either, someone could hijack api.dropbox.com via DNS cache poisoning, and get your info. They call HTTPS with plaintext oauth secret key in the URL.
display_name=my name
quota=24561844224
email=my@email.addr
dbox_utils.c:84(debug) [curl]* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
box_utils.c:84(debug) [curl]< GET /1/account/info?oauth_consumer_key=REDACTED&oauth_token=REDACTED&oauth_signature_method=PLAINTEXT&oauth_signature=REDACTED&oauth_timestamp=REDACTED&oauth_nonce=REDACTED HTTP/1.1
# cat /etc/frontview/dropbox/config.xml
<DropBoxConfiguration xmlns="urn:netgear:nas:readynasd" mode="bidir">
<ShareId><![CDATA[data/readydrop]]></ShareId>
