danielw
Apr 30, 2013Aspirant
Dropbox Syncing Problems
Hi Guys, I am currently using the new Netgear NAS 102 with the OS 6.0.4 firmware on it and am having issues with Dropbox sync I hope you can help with. I have set the DropBox to syncronise my ...
danielw
May 08, 2013Aspirant
Thanks for the help Guys.
Yes, I have an upgraded DropBox account so I currently have just over 100GB of storage available. The upload speed I am working with is 1.2 mbps so appreciate its going to take probably over a week to upload everything.
I don't seem to remember it uploading and then downloading stuff after each boot on the old firmware. I have noticed that it actually uploads only a certain amount and then downloads everything after a certain amount of time regardless of reboot.
Do you think it would be better to upload evrything to dropbox then move this folder into the apps folder so it downloads it to the netgear nas. Will this change the way it sync's or should I look to change the code you suggested?
