millera1
Sep 23, 2011Aspirant
Duo initial setup - setup is greyed out
I have a brand new ReadyNAS DUO purchased from Amazon. I have tried to install this for the first time tonight. The unit was supplied with zero drives as I wanted to install 2 x 2Tb WD drives which ...
millera1
Sep 24, 2011Aspirant
Many thanks to mdgm and amac27. This seems to have worked and I now see the setup screen. Hopefully its now in the process of setting up a one disk raid set (default setting). I didnt realise I had to hold the reset pin for 30 seconds. I misread the instructions (it was late??!!) and held the power button for 30 seconds - and just did a single click of the reset pin. Curiously the fans seem to be running at max speed still but maybe this will stop when its fully set up. I'll let you know how this goes.
