millera1
Sep 23, 2011Aspirant
Duo initial setup - setup is greyed out
I have a brand new ReadyNAS DUO purchased from Amazon. I have tried to install this for the first time tonight. The unit was supplied with zero drives as I wanted to install 2 x 2Tb WD drives which ...
mdgm-ntgr
Sep 24, 2011NETGEAR Employee Retired
That does sound like it's working now. After you do a factory reset there is a 10 minute window in which you can choose RAID modes. If you don't choose a mode, the default X-RAID (recommended) is chosen.
When you add a second disk to a X-RAID array redundancy will be setup.
