millera1
Sep 23, 2011Aspirant
Duo initial setup - setup is greyed out
I have a brand new ReadyNAS DUO purchased from Amazon. I have tried to install this for the first time tonight. The unit was supplied with zero drives as I wanted to install 2 x 2Tb WD drives which ...
millera1
Sep 29, 2011Aspirant
So this is now all working. I can see the volume is fully synched up and I have been thru initial setup. have set up a CIFS share and can successfully access it from Windows XP just fine. Did an MSBACKUP of my c:\ and sucessfully wrote 33Gb of backup file. So this is working ok.
HOWEVER - I cannot - despite how much I try, get a share advertised over BONJOUR to be visible via AFP on LEOPARD. All the instructions just dont seem to work. I have tried in Finder, select Go>Network>My Network>AFP but in fact under GO>NETWORK I see SHARED and in there I can see my duo. But it only shows CIFS shares not my AFP share. The share is ONLY advertised by AFP not both.
