ksor1
Jun 27, 2022Aspirant
Duo problem ??
My Raidar shows this: The % doesn't move over the day ! What does it mean and what should I do ? The drive seems to work.
- Jun 28, 2022
ksor1 wrote:
Still it could be nice to know how to again access the web site - any ideas ?
What happens if you access https://192.168.1.99/admin from internet explorer? Can you post a screen shot of any error?
Jun 27, 2022Guru - Experienced User
Something put the two drives out of sync, and the system is trying to recovery the RAID-1 volume.
Try downloading the full log zip file from the logs page of Frontview, that should help us figure out what is happening.
ksor1
Jun 28, 2022Aspirant
When I try to acces the web site of the Duo - a message saying that it's not avaiable is coming up !
Over the years I've had a lot of problems when updating Windows - the Duo can not be found because of some older "services" is left out in the new Windows update - maybe that is the cause of web site not avaiable.
This morning the Raidar gives me this picture:
So it seems like it during the night has cured itself 🙂 - nice !
(BTW: the re is a lot of problems intering this forum because of login problems - it seems lilke a total mess - the email advicing me of a reply can't be used to enter the forum !
WHO takes care of these problems ? )
- StephenBJun 28, 2022Guru - Experienced User
- ksor1Jun 28, 2022Aspirant
YES, very nice - this https://192.168.1.99/admin worked - except i had to enter user name and password in a dialog - but I did get access !
THX !
I can see all the logs too - there are a lot of them ! - but I KNOW what caused the problem yesterday - a lightning struck nearby and took all the power !
When I earlier wrote that I couldn't view the web site - it's the device icons in Windows that doesn't allow access - but now I can just use this address abowe.
THX for your time and answers !
