Chandler1
Sep 01, 2014Aspirant
Duo v1 - Recover data from a spanned volume
Hi all, I did find this post here that said I'm screwed (and it's my own fault too!), but figured I'd just put up a post just-in-case... Situation: Duo v1, 2 x 1TB drives configured as a span (...
mdgm-ntgr
Sep 01, 2014NETGEAR Employee Retired
Hope you can get some data back, but spanned RAID-0 is horrible when it comes to data recovery.
If you get lots of errors reading disk 2 you might have to try cloning it.
If you must use RAID-0 a separate volume for each disk is the way to go.
Whatever RAID level you use backups are important.
