Metalguru69
Jan 30, 2014Aspirant
Duo v1 not booting
We had a power cut. On restoring power the ReadyNAS appeared to start to boot OK and for a brief time responded to a network ping. Then after about two minutes it became unresponsive to a ping. The on...
Jan 30, 2014Guru - Experienced User
One option is to use linux reader (http://www.diskinternals.com/linux-reader/). Use disk 1 (it won't read disk 2), and make sure the NAS is powered down when re-inserting. This requires connecting disk 1 to a windows PC (either SATA or through a USB adapter).
You could also try powering down, and attempt to boot with disk 1 only, or disk 2 only.
