Metalguru69
Jan 30, 2014Aspirant
Duo v1 not booting
We had a power cut. On restoring power the ReadyNAS appeared to start to boot OK and for a brief time responded to a network ping. Then after about two minutes it became unresponsive to a ping. The on...
vandermerwe
Jan 30, 2014Master
I hope you do not lose data.
There is a lot of advice dispensed on the forums about backups, but not as much effort is put into promoting the use of UPS. There are a phenomenal number of problems reported that are associated with power cuts, and it's relatively simple and cheap to prevent these problems.
Metalguru69, I hope you have a backup, and you will I'm sure now use an UPS.
