mattuk
Jul 04, 2015Aspirant
Duo v1 Radiator 4.1.14 Fan maxed out and wont recalibrate
I upgraded to Radiator 4.1.14. I then discovered that all my user accounts had been disabled and will not list in Frontview or allow me to re-create them because they already exist! The fan was runni...
markiivi
Feb 22, 2016Aspirant
I am having the same fan issues described above; I have backed up the two 2TB drives which were in a RAID X config. I have removed those drives and replaced with a much solitary smaller drive in Bay 1; I have reinstalled Raidiator 4.1.14 for the second time and FACTORY reset twice too for good measure. The fan is running at 5769 rpm and will not recalibrate although the confirmation window does pop up to say it will do the job over next few minutes. May I please have the fix for this?
Many thanks
BrianL2
Feb 22, 2016NETGEAR Employee Retired
Hi peta, bclay & markiivi,
The Beta Firmware can be downloaded here.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBFeb 22, 2016Guru - Experienced User
BrianL2 wrote:
The Beta Firmware can be downloaded here.There are no fan fixes over 4.1.14 though - just security patches.
- markiiviFeb 23, 2016Aspirant
Thanks for the link to the Beta software; comms with the unit is noticeably smoother and not so lagging. But the fan is still screaming away at 5769 rpm! Is there any way to calm down the fan - a 'fan fix'; the RND is not being used for anything at all so under no stress.
Cheers
Mark
- JennCFeb 23, 2016NETGEAR Employee Retired
Hello markiivi,
Can you try the Recalibrate button for the fan?
