mattuk
Jul 04, 2015Aspirant
Duo v1 Radiator 4.1.14 Fan maxed out and wont recalibrate
I upgraded to Radiator 4.1.14. I then discovered that all my user accounts had been disabled and will not list in Frontview or allow me to re-create them because they already exist! The fan was runni...
mdgm-ntgr
Jul 08, 2015NETGEAR Employee Retired
It looks like the EEPROM on your system is messed up. This is rare on the Duo v1 but it can happen. Sent you a PM.
- bclayNov 07, 2015Aspirant
Having the same exact issue.....can you please PM me what the fix is?
- markiiviFeb 22, 2016Aspirant
I am having the same fan issues described above; I have backed up the two 2TB drives which were in a RAID X config. I have removed those drives and replaced with a much solitary smaller drive in Bay 1; I have reinstalled Raidiator 4.1.14 for the second time and FACTORY reset twice too for good measure. The fan is running at 5769 rpm and will not recalibrate although the confirmation window does pop up to say it will do the job over next few minutes. May I please have the fix for this?
Many thanks
