Kornmod
Apr 15, 2012Aspirant
Duo v2 and PS3
I've just bought a ReadyNAS Duo V2 primarily to backup my dvd's and to play them via my PS3 and I have some problems in that regard that I hope somebody can help me with. I've running my ReadyNAS in ...
Kornmod
Apr 16, 2012Aspirant
Hi JarnoG.
First of all thanks for your reply.
I don't have ReadyDLNA installed. I use the build in DNLA function (from what I read then it's only Duo v2 and NV+ v2 that has this) but I suppose it doesn't make any difference. I can always see the 3 media folders but whenever I access the folders I can't see any files, neither those that are in the root directory nor those that are in the folder I’ve created, and it doesn’t make any difference whether DLNA is on or off. If I browse by folder I can see all the files in that folder.
I can't find where to update the DB manually and I think I read in one of the other threads that the v2 units don't have such a button. I have both tried to restart my PS3 as well as reload the mediaserver list (I read in a PS3 forum that when you do that, the directory structure is updated.) And once again I've tried with DLNA in both on and off.
About the first: ReadyDLNA organizes your data in two ways for you. One is the folder structure in which you store your files. The other one is in virtual folders sorted by media type. It sorts all video's together, all music together and all photo's. You can then search through those media types by type-specific properties like genre, artist, etc.
The second can be two things.
- ReadyDLNA should keep track of the changes in the folders. However, it might take a (short) while. In some cases it does not automatically update, then you can manually update the database via Dashboard. (at least, that's how it works on my Ultra, I'm assuming it works approximately the same on the Duo v2)
- The PS3 does not reload the folder content each time a folder is accessed. So if the PS3 doesn't ask for an update, you can only find out if a file is gone by opening it. You can try to make the PS3 reload the folder by browsing to a different media server and then back or by manually making it search for media servers.
