Kornmod
Apr 15, 2012Aspirant
Duo v2 and PS3
I've just bought a ReadyNAS Duo V2 primarily to backup my dvd's and to play them via my PS3 and I have some problems in that regard that I hope somebody can help me with. I've running my ReadyNAS in ...
Kornmod
Apr 16, 2012Aspirant
I have tried to install ReadyDLNA, ReadyDLNA debug toggle and DLNA rebuild db add-on's as suggested. In the log it says that the add-on's were installed successfully but when I check which add-on's there are installed it only shows ReadyNAS Photo II (pre-installed) and ReadyNAS remote. Also now I can't find any files on my ReadyNAS via the PS3 even with DLNA turned on. I've tried to restart both the ReadyNAS and the PS3 as well as reloading the mediaserver list.
