Kornmod
Apr 15, 2012Aspirant
Duo v2 and PS3
I've just bought a ReadyNAS Duo V2 primarily to backup my dvd's and to play them via my PS3 and I have some problems in that regard that I hope somebody can help me with. I've running my ReadyNAS in ...
mdgm-ntgr
Apr 19, 2012NETGEAR Employee Retired
Kornmod wrote:
One thing though. I have tried to install DLNA rebuild DB (ARM version). The system log says that the add-on was installed successfully but it doesn't show under the "installed add-on's" and nothing seams to be changed in the other menus. Any ideas??
That's expected. All it does is stop ReadyDLNA, delete the DLNA database then restart ReadyDLNA forcing the database to be rebuilt. If you download the logs you should see in upnp-av.log that the database has been rebuilt.
The ReadyDLNA update add-on updates ReadyDLNA and the Toggle Debug add-on toggles on/off debug mode for ReadyDLNA with more verbose logging. Neither of these add-ons require a web interface either.
