richdraper
Jul 16, 2021Aspirant
Duo V2, Drive Capacity Cap?
Hi All,
First post here, as the title really im wondering if the Duo V2 has a drive capacity cap. I'm looking at sticking in 2x 10TB. Out of the following list does anyone know which would fair better reliability/longevity wise?
- Seagate Iron wolf (ST10000VN0008)
- WD Red + (WD101EFBX)
- WD Red Pro (WD102KFBX)
- N300 (HDWG11AUZSVA)
documentation seems to suggest a 4tb cap, this is probably more due to technology available at time of print rather than capability of the nas itself
any suggestions warmly recieved
thanks
Rich
richdraper wrote:documentation seems to suggest a 4tb cap, this is probably more due to technology available at time of print rather than capability of the nas itself
Their datasheets use the biggest compatible drives available at the time of publication, and they don't go back and update them later.
There are limits to volume size in the old ReadyNAS, but you won't hit them with 10-TB RAID-1.
One poster did successfully use 2x10TB in their v2 - https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Tutorial-10TB-drives-installed-in-Readynas-duo-v2/m-p/1744735
The WD102KFBX is enterprise class, and has the longest warranty (5 years; the others are 3 years).
Though normally I think enterprise class is overkill for a Duo, it's actually the cheapest at the moment (current US Amazon prices are about $60 less than the Ironwolf and the Red+).
- richdraperAspirant
thanks Mr B
is it possible to get over the 300Mbits/sec(40ish MByte/sec) ive seen quoted from 2009 review or is that about the limit of the v2?- StephenBGuru - Experienced User
richdraper wrote:
is it possible to get over the 300Mbits/sec(40ish MByte/sec) ive seen quoted from 2009 review or is that about the limit of the v2?2009 would be the original Duo - the v2 came out in late 2011. 40 MB/s is definitely high for the original v1, I've gotten perhaps half that.
But large file transfers with the v2 should be in the 40-50 MB/sec range. This is based on what I've read - I don't own any of the v2 ReadyNAS.
