ksein
Sep 19, 2012Aspirant
Duo v2 NFS extremely poor performance
I bought Netgear Duo V2 with WD NAS (red) 2 X 2TB for backup my VM guest from Esxi 5 (Free edition) using NFS by ghettoVCB script. I'm able to create NFS share in Duo and was able to mount on Esxi hos...
ksein
Oct 11, 2012Aspirant
Hi Venzi, My problem is still not solved. I update the new firmware RAIDiator 5.3.6 (arm) and still have issue. What kind of WD drive are you using? Green or Blue or Black ? I plan to test with WD black to see any solution. I just get the drive. I'll post it any update after the test.
