valsa1
Aug 06, 2014Aspirant
Duo V2 one disk expansion
Hi all , I have a duo V2 with 1 disk 1Tb installed in X-RAID2. I wanted to expand and bought a brand new 3Tb disk Added the new 3Tb disk to the NAS , sync started and anded after 5 hours successfu...
Oct 25, 2014Guru - Experienced User
When you installed the 4 TB drive, XRAID2 migrated you to RAID-1. Volume size is 1 TB to match the smallest disk.
Removing the 1 TB drive then results in the volume being degraded. However it is still 1 TB. You can purchase a second 4 TB drive, and insert it in the empty (or 1 TB) slot. That will expand to 4 TB, and will be protected.
The simplest way to back up your NAS to a local PC is to drag/drop the folders on the NAS to PC folders. I suggest downloading teracopy, and using it's verification mode. It will take longer, but it ensure that everything is properly copied.
There should be no problem restoring the folders. After the reset you will need to recreate the shares (putting some of them on the 1 TB volume, and the rest on the 4 TB volume).
lforbes
Sep 02, 2015Aspirant
So I had two disks, both JBOD and separate volumes both 3TB. My 2nd Volume Disk 2 died and I replaced it with a 4TB. However, the JBOD detected it ONLY as a 3TB and created a new 2.7TB volume instead of the 3.7TB.
It did NOT auto-expand from the original settings. I have the latest software and firmware.
This software is very pathetic.
- mdgm-ntgrSep 03, 2015NETGEAR Employee Retired
We recommend sticking with the default X-RAID2. With non-redundant volumes if a disk fails and you have no backup you may lose all your data.
You could try backign up your data, doing a factory default (wipes all data, settings, everything), choose JBOD and then restore your data from backup.
- lforbesSep 03, 2015Aspirant
The RAID is not useful because you put in 6TB and get 3TB of usable space. I don't want to pay 2x as much for the same amount of space for a backup drive. I don't need a backup of my backup.
The whole purpose of JBOD rather than a raid stripe is that if one drive failes you lose only 1 volume, not both.
JBOD is the best configuration because one drive failed but I could use my 2nd drive for months before replacing the first.
I know I can do a factory reset but then that just means that Netgear software is defective. The whole point of having a JBOD is that you shouldn't have to do a factory reset.
As as an engineer I get asked a lot for the best companies for hardware and I am so far not impressed with the limitations of Netgear at all.
The Netgear manual website says the drive will "expand" automatically so if it doesn't does this mean the NAS hardware is defective?
- StephenBSep 03, 2015Guru - Experienced User
lforbes wrote:
... The whole point of having a JBOD is that you shouldn't have to do a factory reset.
But you didn't choose to use JBOD, and you certainly knew you were set up for XRAID.
The hardware is fine. Your link is clearly for Flex-Raid, and you were using XRAID- which is explained quite clearly on page 19 of the software manual (http://www.readynas.com/download/documentation/UM/RAIDiator5-3_Home_SW_en_Nov711.pdf):
With X-RAID2, you can start out with one hard disk, add a second disk for data protection, then add more disks for additional capacity, and X-RAID2 accommodates the new disks automatically.
If you are saying that you should have been able to convert xraid to jbod before you inserted the second drive, then I'd agree. Netgear has provided a non-destructive control to switch between flexraid and xraid on the newer OS-6 NAS, but chose not to retrofit the older Raidiator 4.x and 5.x firmware with that particular feature.
But here you simply added the disk without taking the time to read the manual. So I'm thinking this is really on you, not Netgear.
That said, it would be convenient to be able to downgrade raid-1 back to jbod. It is a corner case (you couldn't downgrade a 3 disk RAID-5 array to a 2 disk RAID-1 array, and most other disk-adds simply can't be undone w/o data loss). However, the corner case would still be worth implementing in a future version of OS 6.
