WonderSlug
Jun 26, 2012Aspirant
Duo V2 RAIDiator 5.3.5: How to change USB drive share name?
It appears that under 5.3.5 the changing of the share name for a USB drive is inaccessible from the gui admin. Is there a way to force the change of the share name for an attached USB drive? Thank...
WonderSlug
Jul 01, 2012Aspirant
You cant change the name of the USB share? That seems like a bug. You were are to do it on the previous versions of RAIDiator. I can do it on my NV+ with 4.1.8. Is this limited to the DuoV2? What about on the NV+v2 and others?
