NASNoob11
Sep 06, 2013Aspirant
Duo-v2 upgrade HELP
OK, I have unpacked my old Duo-v2 (rnd2000-200NAS) again to set it up to go live with my Brother on his LAN. I have upgraded its' f/w to v5.3.8, host name, and modified/added some shares. I chose to u...
vandermerwe
Sep 07, 2013Master
The purpose of testing the dhcp assignment is to make sure the NAS can get an IP address other than 192.168.168.168.
You have made it very clear that you don't want to use dhcp in your earlier posts.
I also use static ip addresses only.
Good luck, try the beta, you seem to have given up so you don't have anything to lose.
