aalexandrebeta
Feb 02, 2017Master
dust removal
Guys what is the best way to remove dust from the device?
- Feb 03, 2017
If you do attempt to clear dust from the inside the unit, it's important to be careful with the fans. You don't want air to spin the blades. General advice is to hold the fins of the fan before trying to vacuum or run compressed air through the air intake.
Opening the unit also likely voids the warranty.
JennC
Feb 03, 2017NETGEAR Employee Retired
Hello aalexandrebeta,
I'm not sure how ReadyNAS users deal with this but I guess mounting your unit with much room for cooling air to circulate and to make sure it does not draw air in on where dust settles would help. Also, clean the air intakes of the NAS regualrly.
aalexandrebeta
Feb 03, 2017Master
I wanted to confirm if I was doing it right!
Thanks!
- StephenBFeb 03, 2017Guru - Experienced User
- aalexandrebetaFeb 03, 2017Master
"Opening the unit also likely voids the warranty." That is WHY I wanted to have a confirm onmy process!!!
Once a year I turn off the unit unplug the device remove the HDD remove the dust and done deal not suffficient but I do not want to void the warranty!
Anyway I do good and this is the only way so I stick with it!
JennCI do not understand user putting their devices into a closet, all my devices appart of Raspberry pi are having some fresh air to breathe!
