glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Oct 21, 2015Tutor
walshlink wrote:Installed an Intel Xeon X3230 in my ReadyNas Pro 6 ( RNDP6000-200 ) over the weekend with OS 6.4.0 installed. CPU temp runs around 48C. Fans and performance graphs seem to work just fine.
Good for you! It seems that some of us who were running "fancontrol" from the early days of OS 6 are not so lucky. I have two Pro 6's. One that has been "Factory Default'ed" which works perfectly in every way, and one that has been running OS 6 from one of the very first versions that was capable of running on legacy hardware. That one is having this problem: https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/m-p/990867#U990867 ever since I upgraded to version 6.4
Me hopes this gets resolved in the next version. If not, it looks like I may have to start looking for a place to temporarily store 9 or 10 TB's of data, format, restore, rince, repeat. . . :smileyfrustrated:
