glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
petermac
Jan 02, 2016Apprentice
Only install the fancontrol if you need to.
WingDog
Feb 15, 2016Guide
Hello.
can you provide additional config steps for fancontrol at 6.4.2? I'm new at linux.
I've got system fan 2220 RPM after one month powered-off device and now can't figure out how to fix this annoying noise!
tried update 6.4.1->6.4.2 but no luck.
thanks!
