glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
panosnl
May 31, 2016Aspirant
I installed OS 6.5.0 which now has its own fancontrol in the NAS GUI. This sounded nice but the "quiet"setting is still too loud, much louder than when I was using fancontrol.
Now the fancontrol does not work anymre.
Any fixes to control the PWM settings of the new fancontrol?
- markwollMay 31, 2016Guide
I just did the 6.5.0 and the fan control is interesting at best.
It is reporting 10 fans. Fans 4-10 show zero rpm.
It is also showing temp1-temp6 with temp2,3,4 with -128C temps. Cool! to say the least.
The temps are ok, it just appears that sensors for non existant devices are active.
How do I tell the system to disregard the missing sensors?
