glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Anton_
Dec 05, 2022Tutor
Need some help!
Running ReadyNAS 4 Ultra with OS6.
In the performance tab, the fan profiles silent, balanced and cool are ignored when i switch between them.
This worked with OS4 though.
I replaced the loud and noisy fan with a Noctua NF-A9 FLX.
The GUI reports correct RPM and temperatures for CPU and System.
But there are just no control of the fan it seems.
Included liblmsensors are using ULTRA4.conf as the configuration file.
system.conf -> /etc/frontview/sensors/ULTRA4.conf
Anton_
Jan 02, 2023Tutor
Any updates to this? Any solutions?
