glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Iridabike
Jun 25, 2013Aspirant
Paste the script text into a text file using a Linux compatible text editor. In Windows you can use Textpad. Save the file on the Nas with a name like TempUpdate.I store mine in the directory /data/Tims
Then edit /etc/crontab and add the line below:
*/1 * * * * root /data/Tims/UpdateTemp
I am no expert but Google is a good help for each step.
