glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
fastfwd
Jul 01, 2013Virtuoso
ATCIS wrote: find / -name syslog --> Yields nothing :( It would appear that syslog is M.I.A.
Check the process list:
ps -A | grep syslogd
That should return something like "1234 ? 00:00:01 syslogd". If it returns nothing at all, syslogd isn't even running.
Tracking down WHY it isn't running might be an interesting exercise. Could be something as simple as an old lockfile preventing it from starting (to check, look in /var/run for a file called "syslogd.pid"; if you see it there even though syslogd isn't running, delete it and restart).
