glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
fastfwd wrote:
ATCIS wrote: find / -name syslog --> Yields nothing :( It would appear that syslog is M.I.A.
Check the process list:ps -A | grep syslogd
That should return something like "1234 ? 00:00:01 syslogd". If it returns nothing at all, syslogd isn't even running.
Tracking down WHY it isn't running might be an interesting exercise. Could be something as simple as an old lockfile preventing it from starting (to check, look in /var/run for a file called "syslogd.pid"; if you see it there even though syslogd isn't running, delete it and restart).
I edited the crap out of my original post above. . . Check it out :)
I have to go to bed now. I have to get back up in less than 5 hours. A special THANK YOU" to fastfwd for all your guidance.
I'll catch up with you guys later. . .
