glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
fastfwd wrote: The -128 is certainly erroneous. The temp3 input is clearly not being used.
The 57-degree SYS temperature is probably right; is that how hot your Ultra4 ran when you were using RAIDiator 4.2.23?
Probably not, but I honestly don't remember without a shadow of a doubt. I may switch it to temp2_input even though 31 degrees C seems too low. On the GUI I have three thermometers: AUX = 40 C / 104 F, CPU = 43 C / 109 F, and System = 40 C / 104 F. Which leads me to believe that those graphical indications are also erroneous or I'm CAT'ing the wrong files. Wouldn't you agree that for a device residing in an 80 to 85 degree ambient environment that a System temperature of 134.6 F seems kind of high when the CPU temperature is only 109.4 F?
I've changed the script accordingly. It now looks like this:
#!/bin/sh
Coretemp="/sys/devices/platform/coretemp.0/temp2_input"
Systemp="/sys/devices/platform/it87.2576/temp2_input"
Ct=`cat $Coretemp`
C=`expr $Ct / 1000`
St=`cat $Systemp`
S=`expr $St / 1`
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:$C:$S
Additionally, my /etc/crontab file now looks like this (perhaps my script file is okay, I just dorked up the crontab):
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. These files also have username fields,
# that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow user command
17 * * * * root cd / && run-parts --report /etc/cron.hourly
25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6 * * 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6 1 * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
# Delete the lines below if things get wacky. They are supposed to enable
# temperature graphing in the Frontview GUI. Good luck!
*/1 * * * * root /usr/local/etc/scripts/UpdateTempGraph.cron
You thoughts?
Thanks again!
