glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Iridabike
Jul 01, 2013Aspirant
Are you running 6.0.8? Netgear changed some stuff around and you need to patch readynasd to make it work correctly.
To start with is this file present on your machine:
/run/readynasd/stats/temperature_int_deg.rrd ?
If it is then try entering this command about 10-15 times over a couple of minutes and see what happens in the graph:
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:25:50
